1987 Nissan 300zx
MMiskoe
1987 Nissan 300zx
Post by MMiskoe » Thu Sep 30, 2010 9:36 pm
1987 Nissan 300zx built for SCCA ITS
NASCAR door bars on both sides
RH side net
19 row oil cooler w/ remote filter & t-stat
Oversized radiator – (never worry about over heating)
NISMO clutch LSD differential
Fire system
New motor in 2009
New clutch last season
Nis-Tune programmable ECU
Mechanical oil pressure, oil temp & water temp gauges
Fully adjustable rear suspension (camber & toe)
Urethane suspension bushings
Camber plates in front, coil overs at all 4 corners
16 identical 6 ½ x 15 wheels
All records & notes available
Extensive collection of spares
Annual tech current through September of 2011
This is a very reliable car, 4 mechanical DNF’s in its entire life (25 races +/-). Needs gas & set the tire pressures, otherwise is ready to go racing, leave it on the trailer between events if you like.
This season has yielded three Second places and four Third places out of seven races. $6000
Located in New Hampshire, can deliver w/in greater New England Area.
MMiskoe57 at Comcast.net
603-228-0257
http://s282.photobucket.com/albums/kk25 ... 0zx%20ITS/
MMiskoe
Re: 1987 Nissan 300zx
Post by MMiskoe » Sun Jan 23, 2011 2:35 pm
bump with more pictures.
Post by brucesallen » Sun Jan 23, 2011 4:46 pm
This car hasn't been raced, has it?
MMiskoe
Post by MMiskoe » Sun Jan 23, 2011 8:10 pm
Not since the snow fell....
This one actually only filled up a log book this past summer. Art Pistey's old car is still racing down in the Maryland area.
Marcia Gentile
Post by Marcia Gentile » Thu Sep 01, 2011 3:54 am
Not bad! Actually i think its much better to repaint this. But the accessories and some Nissan parts are fine. It's still looks good. :) Just a change of color will do and this would be perfect for racing. :)
Last edited by Marcia Gentile on Mon Sep 05, 2011 2:24 am, edited 1 time in total.
Post by CP » Thu Sep 01, 2011 2:01 pm
Some video of the car in action (skip ahead to about 7:00):
Post by Chrispy » Fri Jul 20, 2012 9:59 pm
CP wrote:Some video of the car in action (skip ahead to about 7:00):
Trading places twice a lap, that's pretty cool.
Post by CP » Mon Jul 23, 2012 4:16 pm
Yeah, we had fun that race. It's nice to be able to race somebody clean.
Post by brucesallen » Wed Jul 25, 2012 12:06 pm
This car hasn't had a con rod punched through the side of the block when I was instructing in the right seat and your friend downshifted to second at 90 mph coming into turn 3 at NHMS instead of braking, is it?
