Coming back to comscc after a difficult 2011
Neptune441
Re: Coming back to comscc after a difficult 2011
Post by Neptune441 » Wed Jul 25, 2012 6:59 pm
Oh yeah I'll be there eventually Brendan. Thanks for the tips, I have plenty of elevation changes and various road conditions around me.
Adrian
horizenjob
Post by horizenjob » Fri Jul 27, 2012 1:22 am
LOL I'm not going to put it up on an engine stand
I meant an engine dyno? It's what people do with race engines and it's not because they can't think of anything to do with their money. I would think it costs less then a weekend at the track. Anyway you go, good luck with it though..
Neptune441
Post by Neptune441 » Sat Aug 04, 2012 6:56 pm
I've decided I'm going to break it in on the dyne, better control, and probably going with Royal Purple engine break in oil, then switch 15w 50 for race / then 5w40 winter/daily Driving. It'll actually cost the same as track weekend 450.00.
Adrian
Post by chaos4NH » Sun Aug 05, 2012 7:30 pm
We are still waiting.
Neptune441
Post by Neptune441 » Sun Aug 05, 2012 10:14 pm
motor will be ready to drop in this thursday then waiting on turbo.
Adrian
Post by brucesallen » Mon Aug 06, 2012 2:56 pm
Isn't it best to break in with conventional oil? The idea is to wear-in key parts like rings and bearings and synthetic won't allow any wear.
Neptune441
Post by Neptune441 » Mon Aug 06, 2012 4:07 pm
Royal Purple has a specific oil made strictly for break in. This is what I am going to use.
http://royalpurpleconsumer.com/products ... ak-in-oil/
Adrian
Post by Mark Swinehart » Mon Aug 06, 2012 10:13 pm
I have used Joe Gibbs oil for engine break-in and it has worked very well.
http://joegibbsdriven.com/products/engi ... index.html
Brendan
Post by Brendan » Tue Aug 07, 2012 7:39 pm
I've heard it argued both ways pretty vehemently on which oil is best. "Don't use synthetic" vs. "Synthetic is fine - the OEM's use it, why wouldn't you?" I know of cars broken in successfully using both dino oil or synthetic, so I pretty much think either will work as long as you break in the motor properly.
But for what it's worth, I used Brad Penn break in oil for the first half hour on the dyno (and the engine before that, the first 100 miles on the street) before switching to a good full synthetic.
Make sure to change your oil filter early too - you'd be surprised at the amount of crap that gets filtered out on a new engine...
#04 SPC
White 1990 E30 M3
Neptune441
Post by Neptune441 » Sun Aug 19, 2012 3:59 pm
Mark Swinehart wrote:I have used Joe Gibbs oil for engine break-in and it has worked very well.
I was eyeing that stuff too Mark.
Brendan wrote:I've heard it argued both ways pretty vehemently on which oil is best. "Don't use synthetic" vs. "Synthetic is fine - the OEM's use it, why wouldn't you?" I know of cars broken in successfully using both dino oil or synthetic, so I pretty much think either will work as long as you break in the motor properly.
Brendan , I've heard it too going like that, Makes my head spin lol On a side note, I'll have about 6 qts of royal purple break in oil left so if anyone needs it let me know.
Adrian
Post by 962porsche » Mon Aug 27, 2012 11:50 am
after missing the 2011 and the 2012 season your just going to blow the motor sky high any way !
o-crap did i say that out loud ?
Neptune441
Post by Neptune441 » Sat Sep 29, 2012 9:40 am
962porsche wrote:after missing the 2011 and the 2012 season your just going to blow the motor sky high any way !
I wanted to join you David with all your chains start nicknaming you alice n chains ;-)
After 1400 almost 1500 miles the motor hasn't consumed oil , and everything is looking good. The only issue I'm running into now is with the light weight flywheel /LTFT. I hear it's common for newer engines to throw CEL for Misfire too. I'm really trying for an October run but we shall see...
Adrian
Post by chaos4NH » Sat Sep 29, 2012 9:54 am
A light weight flywheel with 600 HP? Hhhhmmmm, I think I would have gone with something heavy. Not like you are competing in anything that will give you benefit of a wimpy flywheel :D
BTW, Oct 13 and 14 entries nearly maxed out.
Neptune441
Post by Neptune441 » Sat Sep 29, 2012 12:10 pm
Sent you a pm on your phone Sam.
Adrian
Post by 962porsche » Sun Sep 30, 2012 8:00 pm
at the least i'm making more more thru every event so i am making head way with the drive line issues . it's not the chains any more it's now in the rollers of the chain tensioner . so some day i will get this car up to speed with out things braking .
it would be good to see you at the nhms 4 event . did you ever get signed off for your comp license with comscc ?
