LRP Weather
LRP Weather
Greetings -
10 day forecast indicates sunny and mid forty's Fri & Sat. Life is good!
Don
Don
Re: LRP Weather
dont get your hopes up... it always finds a way to rain ...Don P wrote:Greetings -
Don
Anti freeze
Done, Mick. Good for 14 degrees.
Now for my blood in a car with no windshield... :-&
Hot blooded
"Now for my blood in a car with no windshield"
Peppermint schnapps at the end of the day should be good antifreeze for the blood.
I promise to blow hot exhaust on you Bruce as you go by :fart:
Dan...too many uses of the words boy and studs in the same sentence.
Is it ok if I hang out just outside the doorway and soak up some of the escaping heat ?
Re: Hot blooded
"Peppermint schnapps at the end of the day should be good antifreeze for the blood."
Scott,
It'll be too late by the end of the day. Will need to swallow nitromethane by then. :help:
Scott,
- Mario Fallas
