2" rule for helmet clearance
- tju-vette
In following the 07 rulebook thread the subject of 2" of helmet clearance came up in regards to targa topped vehciles (I had posted in that thread as well before it was locked).
Is this a hard & fast rule? Is it something new for '07?
I'm 6'4" and drive a C4 corvette. I run the lexan roof already and have lowered my seat to gain headroom but will fail the 2" rule without a doubt if it means inside clearance. If it means it is 2" below the highest point of the car I might be OK but it is hard to measure.
I did run the 1st day @ NHIS last July and it didn't seem to be an issue. I'd like to run with COM again, and more often but am not sure if I'm compliant.
I had hoped to get get in touch with Bill F via email but they keep getting kicked back to me so I hope to get some definite answers here from any Steward or Tech Inspector.
Any feedback would be appreciated.
				ryanthieme
You mean Clint Bowyer, right?brucesallen wrote:the rule DOES mean 2: from the outside of the car. The SCCA thinking is that your head should not be the first thing hitting the rocks when your car is sliding upside down.
Now we know why Harvick didn't have a sun roof at Daytona.
 ~ryan
Ryan Thieme
#334 ST3 Miata
						#334 ST3 Miata
- tju-vette
Understood and thanks for the clarification.brucesallen wrote:the rule DOES mean 2: from the outside of the car. The SCCA thinking is that your head should not be the first thing hitting the rocks when your car is sliding upside down.
So how do I go about having one of the tech inspectors or stewards ensure that I'm compliant BEFORE my first event?
As an FYI last year I had to make several changes for other instructors smaller in statue (all COM instructors rate very HIGH for me BTW) because of this rule. Most Miata's (one Alfa Spider) I was assigned to last year I had to change because my 6'2" frame would not fit into it.
It only makes good sense to have proper clearance. If you are a student, also account for Instructors who may be taller than you. A bar raised more than 2" is NOT going to slow you down. So err on the caution of safety especially for taller instructors.
